04-23-2019 00:39 - last edited on 11-17-2020 11:10 by MatthewFitbit
Hi guys, how do I track 'Badminton' as my activity on the Fitbit?
04-23-2019 05:25
04-23-2019 05:25
Welcome to the forums!
Make sure on your shortcuts you have Workout Mode. Use this when doing an activity. Then set up a custom Exercise on your dashboard called Badminton. Once it sync you will be able to rename it.
You will find custom activity at the bottom of the Exercise tab on the computer Dashboard
Looking forward to seeing you around the forums!
Wendy | CA | Moto G6 Android
04-23-2019 05:25
04-23-2019 05:25
04-24-2019 10:02
04-24-2019 10:02
Welcome to the Forums @iAsmodeus and @WendyB thanks for the input.
I was able to see here that our friend @WendyB provided some instructions in order to register "Badminton". Was this the answer you were looking for? If it was, I recommend marking the answer given as a solution. By doing this, other users with the same inquiry will be able to find a faster response.
Now, if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out. 😉
07-30-2019 17:30
07-30-2019 17:30
Same question here. When I play badminton with my Charge 3, the exercise was auto detected as Sports only. In the Fitbit app, the exercise shortcuts only provide Tennis but no option for Badminton.
1) I would expect an exercise shortcut at the Fitbit app
2) Is there a way to name the exercise before we start it but not after a sync?
05-11-2020 12:22
05-11-2020 12:22
I have a Fitbit versa 2 special edition. It seems like the device doesn’t support badminton as an activity. However I see “Tennis” as an option to chose from list of activities supported.
Questions:
- Does Fitbit think badminton same as tennis as for as activity tracking is concerned? And suggest to use activity “Tennis” while playing badminton?
- Is badminton not supported activity by Fitbit?
05-11-2020 12:25
05-11-2020 12:25
This doesn’t work as badminton is not one of the activity supported by Fitbit. I expect an answer from Fitbit moderator.
05-11-2020 12:53 - edited 05-11-2020 12:54
@Murthy_Germany wrote:I have a Fitbit versa 2 special edition. It seems like the device doesn’t support badminton as an activity. However I see “Tennis” as an option to chose from list of activities supported.
Questions:
Tennis would work just fine. But you can set up a custom activity and rename the workout mode to that after it syncs if you want accuracy. Custom activity is at the bottom of the Activity tracker
It would be near impossible to list all the activities that are out there
Sorry not a Mod but they are short handed right now
09-14-2020 14:17
09-14-2020 14:17
As the Fitbit is a tracker purely marketed towards fitness tracking it irritates me that there is not more activity presets. The Apple Watch (which is not just for fitness) has a badminton activity. For the hundreds of pounds we spend on a tracker surely we should get more.
11-04-2020 10:32
11-04-2020 10:32
Hi, how can i add shortcut in my versa 3
11-06-2020 09:40
11-06-2020 09:40
Hey @AravindanRamesh, it's great to see you here.
Regarding your inquiry, if you want to edit your shortcuts, you can do it by following the instructions provided in the help article: Can I change or reorder the exercises on my Fitbit device?.
Let me know if you need anything else.
01-04-2022 11:54
01-04-2022 11:54
It doesn't work on Versa 3 .... apparently there is no excercise shortcut function. But on the device itself some excercises are listed but no badminton. Can this be updated?
01-05-2022 05:06
01-05-2022 05:06
Hello @Natalieb06 and welcome to the Community forum. Those instructions on changing and reordering the shortcuts don't apply to the Versa3 because all the shortcuts are on the device itself. When you tap on the Exercise app on your Versa 3, you will see all of the shortcuts in alphabetical order. After you use a shortcut, you list changes to Recent, then everything else. I hope this helps.
Laurie | Maryland, USA
06-23-2022 21:07
06-23-2022 21:07
For badminton, in Versa, I selected the activity as "Workout" and we then renamed it to "Badminton" after sync.
But, Is it possible to add "Badminton" to the preset exercise list, so we can select "Badminton" as the activity when we start an activity rather than choosing it as "Workout" and Renaming to "Badminton" after sync. Its an extra step and we might forget as well.
Sorry I just bought Versa 2 now and trying all options available. Hence appreciate if you could answer on this.
Thanks
07-10-2023 23:32
07-10-2023 23:32
Wish I had checked before I bought the inspire 3 last week. I would not have imagined Badminton not being on the Fitbit app.
Why would I have to keep logging it as a workout and editing everyday when I play? That is 5 times a week.
It's not a game played by a few. Millions play it. Not popular in US and Canada. Other than that, a lot *huge* number of people in rest of the world play badminton. I guess unlike me, they check does Fitbit have badminton, see it does not, and don't buy Fitbit. Seems reasonable enough.
Also, seems very easy to add. Badminton for 1 hour makes one move exactly double as one would after an hour of tennis (1 hour of tennis is approx 1.2 kms and one hour of badminton is approx 2.5 kms) and makes one burn exactly double the calories in the same 1 hour. So, tennis data doubled is exactly badminton as an activity.
Well, I'll give the Fitbit a run for a month, but I am going back to an apple watch it seems, quite clearly. I really liked Fitbit these last few days. Sadly, see no other option.
