10-03-2020
13:00
16:17
10-03-2020
13:00
16:17
How do I setup wrist movement display?
10-03-2020 13:04
10-03-2020 13:04
Assuming you mean having the display come on with wrist turn, press side button a few seconds; scroll down to 'Screen Wake'; tap to toggle on or off; light bulb on without line through it is to turn display on with wrist turn; turn off caps lock.
10-03-2020 13:04
10-03-2020 13:04
10-04-2020
08:27
04:41
10-04-2020
08:27
04:41
It's great to see you around, @Sarge7604 and @JohnnyRow, thanks for the input.
I am glad to see here that our friend replied to your screen wake inquiry. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up!
10-07-2020 07:07
10-07-2020 07:07
Thank you!! Got it!!!
10-08-2020 10:26
10-09-2020 05:40
10-09-2020 05:40
Alejandro, great community support, greatly appreciated!!🤗
01-30-2021 13:41
01-30-2021 13:41
taped nthing happenes
02-01-2021
06:44
04:41
02-01-2021
06:44
04:41
Hey @Sarge7604, it's great to see you around.
Can you please be more specific about the issue you are experiencing? Have you tried the steps in this post?.
I hope to hear from you soon.
03-25-2021 08:08
03-25-2021 08:08
You might need to toggle ON the WAKE SCREEN FEATURE. In addition, you have to checl if SLEEP function is also off.
04-21-2022 07:10
04-21-2022 07:10
So I am having this problem now. It used to work fine. When I go to tap the screen wake to turn it on nothing happens. I can cycle thru the sleep settings but nothing happens when I touch the screen wake. Is there any advise you can give?
