10-14-2022 07:21 - edited 10-15-2022 07:15
Hello,
Edit: after charging it for over a day just to make sure, it still depletes around 5% every few minutes, so I'm confident it is a battery failure and I used the chat support option to request a replacement as it is still under warranty.
I bought and set-up a Charge 5 in early January this year and suddenly this week it has started rapidly depleting battery. I'll describe some specific incidents below but to briefly explain, I charged it all night, and when I put it on this morning it displayed "100%" charged. I wore it for 10 minutes and checked and it was at 83% charge, and by the end of the hour it had powered off. This has happened multiple times in the past 3-4 days but it is dying faster and faster each time. The mobile sync device I use is a Samsung Galaxy A6 running Android (approx. 5 year old sub-flagship model of Galaxy brand). The only notably issue I have been having prior to this week is that my device has not been syncing automatically, so I have to manually open the Fitbit app and when I do so, it often takes several minutes to sync, but I don't think this is inherently related to my current problem and was tolerable.
I believe the device is still under warranty as it is less than 1 year old and after attempting a few possible fixes posted on this website I believe this is hardware failure.
Fixes I've tried:
Any help is appreciated.
Further, more detailed description of issues.
3 days ago after waking up (wore device while sleeping, device had at least 50% battery when going to bed) I checked the time and the device didn't have power, as if the battery had died. I assumed that despite the high battery the day before, maybe I had hit some setting my sleep that caused it to drain the battery (like having it track my heart rate constantly, a feature I've since turned off to make sure this isn't the problem). I got back home later and plugged it in and when it booted on and showed me the charging screen, it reported that it was at 53% charge after only being plugged in for a few minutes. This seemed odd but my only thought was maybe I had some how forced it to turn off somehow or maybe it shut down when I washed my hands or something. Prior to this, the only time I had noticed anything weird battery wise was I had found previously that when charging the device, it would often get to 99% charged and stay there for sometimes another hour before hitting 100% charged.
Since the device was at above 50% charge I put it back on, wore it for the rest of the day, charged it up to 100% before putting it on and going to bed. The following day it functioned properly without issue. Yesterday morning, upon waking up, I checked to make sure it was still working and it showed me the time, so I went to work assuming whatever the problem was got fixed. At work I looked and it was dead again. I assumed something similar to 2 days prior had happened so when I got home, I plugged it in, it booted up and this time reported being at 1% battery (suggesting it had fully died somehow). Unfortunately, I didn't note what the charge was at when I verified it was working that morning, so I'm not sure if it was near dead then. It only recorded 100 steps before dying so it must have died before I even left for work.
After charging it up to around 25% yesterday afternoon, I put it on to see if the battery was holding a charge, and within 5 minutes 25% went to 10% and then within 10 minutes it was unresponsive. I fully charged it to 100% this time (gave it 3 hours to charge) and put it on a few hours before bed, and within an hour it was at under 50% charge. I rebooted it again, verified the firmware as mentioned above, then recharged it before putting it back on and going to sleep. I woke up in the middle of the night around 3 hours later and it was unresponsive again, plugged it in and it said it had 1% battery. From then I proceeded to have the scenario I described near the top of the post this morning.
I apologize for the long post but I thought any information might be useful, please let me know what I should do next or if (and how) I should go about attempting to get an RMA process started.
Max
10-14-2022 10:19
10-14-2022 10:19
Adding my own info: the band is under 4 months old, the issue started after the latest update. Just tested it again with the GPS set to phone only and it lost 21% in 13 minutes. (70 to 49).
10-14-2022 11:23
10-14-2022 11:23
This is happening to my Fitbit Charge 5 as well. It is so frustrating as I have only had this product since March 2022. On Sunday I got an x in a circle on my screen and it has been all downhill since then. I have unpaired and factory reset it and am still having major issues. Very disappointed in this product.
10-14-2022 13:46
10-14-2022 13:46
I'm also having similar issues with mine and this is my second device (that one also had something similar happen a few months ago). I'm very frustrated
10-14-2022 16:59
10-14-2022 16:59
This has happened to me too. It's very odd.
10-14-2022 17:01
10-14-2022 17:01
Fully charged, then within 11 hours it's dead. Won't even charge now.
Spoke to Fitbit and they've issued a new tracker under warranty
Best Answer10-15-2022 01:03
10-15-2022 01:03
Interesting I just updated my phone too. I have the Google pixel 5, android 13.
Best Answer10-21-2022 08:47
10-21-2022 08:47
I just found your post after posting mine. I'm having this issue too. The last 3 days the battery suddenly started depleting from 100% to 4% in under 12 hours. I got mine in May 2022. I made no changes in settings on it or my phone. Prior to the last couple days, it held a charge for about 7 days. There was no gradual loss of life or anything. Just WHAM. I'm really upset because I don't think it's covered by any warranty and it wasn't cheap.
10-21-2022 08:59
10-21-2022 08:59
It should have a 13 month warranty. Contact Fitbit. Good luck!
Best Answer10-21-2022 18:01
10-21-2022 18:01
Mine just did this last night. Fully charged before bed and in 6 hours fully drained. Has anyone had luck with support from Fitbit? Device is 1 year old this month
Best Answer02-14-2023 06:05
02-14-2023 06:05
Fitbit 5 lose 100% of charge within 1 hour. Awful!
Try all recomendations, ith my third Fitbit.
Fitbit 3 - display die after 6 month using
Fitbit 4 - the place of fastening of the strap came off from the watch case after 8 month
Fitbit 5 - start losing 100% of charge within 1 hour when i got to a pool at first time from 06/2022
It seems to me that there is one thing in common in all this - it is obvious that the Fitbit is crap.
