Just bought a Charge 5 - still have a charge 2 that works fine. If switching between them, such as while charging the Charge 5, will my steps both sync and "count" in the app and online?
04:59
06:54
12-08-2022
04:59
06:54
@DanaKay I'm sorry, but other the other advice given to you is incorrect. If a device has a Gallery, like your Charge 5, you can only have one device per account. The Charge 2, an earlier model, doesn't have a Gallery. You can keep your Charge 2 on your account and add the Charge 5.
My husband has a Blaze and a Sense on his account.
Laurie | Maryland
Thank you so much for the quick and helpful reply. (Even if I wish there were a way to have the two sync in the app 😔 )
Best AnswerHi @DanaKay yes, it can be done, but it takes a bit of work to do it. Using the Charge 5, sync and remove it from your account. Set up the Charge 2 and use it. Then sync it, remove it from your account and set up the Charge 5. If you just swap them like that, your one account will accumulate all the activity for you. It's a workaround that should give you what you want.
04:59
06:54
12-08-2022
04:59
06:54
Laurie | Maryland
@LZeeW Oh, wow - you are so right. - both Charges are listed in my account - and because I didn't start using the Charge 5 until I went to bed, the Charge 2 is still active, though not on my wrist. And it has the same number of steps showing on it as the Charge 5 on my wrist! Interesting. (Maybe all those different colored bands I've been wearing on the Charge 2 will not completely go to waste 🤣 )
Thank you for adding this info.
Sorry, but the Charge 5 uses a different quick release system for the bands. The bands aren't interchangeable. You might find one thing a little confusing between the Charge 2 and 5. The Charge 2 gives active minutes and the Charge 5 gives active zone minutes. They awarded differently and aren't interchangeable. You app will show the units for the device you are wearing. Also, the Charge 5 doesn't count floors.
Laurie | Maryland
Best AnswerI know - the band was the first thing I checked! Will check out the zone change. And I realized the Charge 5 doesn't count floors before I bought, but the Charge 2 is not accurate for floors - at least mine never has been. And my home office is upstairs so I am up and down all day and evening, so the inaccuracy was apparent early on - I wasn't using that data anyway. Thanks again for all your help.
