07-18-2022
05:25
09:21
DavideFitbit
07-18-2022
05:25
09:21
DavideFitbit
Hi there. I’m being evaluated for Afib. I can tell when I’m in it but I’m 2 weeks the app has sent only one alert. It usually catches it on EKG. Anyone else have experience with it?
Moderator edit: format
Best Answer07-19-2022 09:20
07-19-2022 09:20
Welcome to the Community forums, @9grand.
Thank you for sharing that you're having this inconvenience with the Charge 5
Before considering other options, let me know if your Fitbit app is updated and if your Charge 5 syncing properly if you've experienced any problem to sync your data.
In the meantime, please give a try to the following steps:
Hope this helps, I'll be around.
