07-11-2022 05:58
07-11-2022 05:58
I felt my heart beating erratically last night for a few minutes while at rest. The atrial fib notification came up on my fitbit, however, there is no report available on the app indicating the abnormal finding. Why would this be?
07-12-2022 05:06
07-12-2022 05:06
07-11-2022 07:11
07-11-2022 07:11
Hi @OhioJen.
Have you tried checking the following - tap the "Discover" icon in the bottom navigation bar - scroll to and tap on "Irregular Rhythm notifications" - tap on the green "View notifications" button - your notifications should be in here?
Best Answer07-11-2022 08:49
07-11-2022 08:49
Best Answer07-12-2022 03:09
07-12-2022 03:09
@OhioJen You wrote that the notification came up on your Fitbit. The Irregular Rhythm Notifications Help article says that this notification appears in your app after syncing (and analysis), not on the device. A High Heart Rate alert will make your device vibrate. Is it possible you got a high heart rate alert? You find high and low heart rate alerts by tapping on your heart rate tile.
Laurie | Maryland
Best Answer07-12-2022 05:06
07-12-2022 05:06
