08-19-2022
07:03
12:28
DavideFitbit
08-19-2022
07:03
12:28
DavideFitbit
Please make the order of stats during exercise editable. Or at least make them make sense.
When I go for a run, my primary concern is usually distance. To get that to display, I have to tap through pace, pace average, heart rate, calories, steps, and time of day first.
If I forget to set it before I start running, I get to do it the first time I think to check my progress, which is usually just when I've gotten warmed up and have started feeling good about running. So I can try to continue running (careening drunkenly like an idiot) while tapping *just so* (it never wants to register, and the screen usually times out several times before I get to the distance stat), or I can stop just as I've warmed up and do it then.
If making this editable is too complex, then at least put distance for a run somewhere before steps, calories, and time of day. I don't know if any runners who would run with any of those goals primarily in mind.
Moderator edit: merged replies
09-12-2022
12:28
04:16
09-12-2022
12:28
04:16
Hi, it's good to see you visiting the Community forums for the fist time, @fullofhands.
Thank you for your inquiry regarding the option to rearrange stats during an exercise on the Charge 5.
As you mentioned earlier, unfortunately this option is not available for the moment, but it would be a very helpful feature for many users. I recommend that you vote for this idea posted in the Feature Suggestion board of the Community, since this section is regularly monitored by the team of developers: Able to customize order of apps/stats on Charge 5.
If you have a different idea, you can also post it separately so other users can vote for it. Make sure to post your idea including as many details as possible.
Thanks again for sharing all your comments and feedback about this!
