06-20-2023 20:53
06-20-2023 20:53
I recently bought the Charge 5, and the band will not come off. I tried my fingernail and a flat screwdriver, the button and the band don't move. I want to purchase a new band, but I can't change it!
I sent a video of me attempting to press the button, and to try to move the band. Nothing. Shouldn't I get a new Fitbit? I didn't receive an email back after sending the second video, which they first said it was black. I just send a normal video, so it's not my problem!
06-21-2023 02:59
06-21-2023 02:59
Hi, @Graffia, welcome, may I suggest you try cleaning the "Charge 5" with warm soapy water? The buttons can sometimes pick up a bit of grit or debris which stops the mechanism from working smoothly. See this video at 3.59 for working the buttons.
I hope this helps.
Cheers
Gr4ndp4 | UK
06-21-2023 11:23
06-21-2023 11:23
06-21-2023 12:04
06-21-2023 12:04
Hi, @Graffia , have you successfully operated the button?
Let us know.
Cheers
Gr4ndp4 | UK
06-24-2023 14:48
06-24-2023 14:48
No, it does not move, I cannot take the band off. I was sent a return label, but the email said I'd be getting another email to tell me what else to return. I didn't get that email, so what else to return?
06-27-2023 03:35
06-27-2023 03:35
Hi, @Graffia , you should ask "Customer Support" who sent you the label.
Cheers
Gr4ndp4 | UK
