05-23-2023
06:41
06:58
DavideFitbit
05-23-2023
06:41
06:58
DavideFitbit
My battery has been lasting 5-7 days but since the update I’m now having to charge every other day. What the hell is going on? How can I change it back so the battery lasts longer?
05-26-2023 06:57
05-26-2023 06:57
Hi, it's good to see you visiting the community forums for the first time, @Kim3083.
I appreciate all this information that you've shared about the inconvenience with your Charge 5.
There are a few features that would make the battery drain faster than usual, even in one day. Some of these features are:
If this doesn't apply to you, another step that has been helpful for other users having battery draining problems is the three pulse restart procedure using the charging cable:
In general, it is recommended to follow the recommendations listed in this article to improve or extend battery life.
05-26-2023 11:01
05-26-2023 11:01
The original charger doesn't work so I have a stand charger. How else can I restart my fitbit?
05-27-2023 08:17
05-27-2023 08:17
Hi @Judy927
You can reset your Charge 5 from the Settings menu on your tracker. Scroll down from the clock face until you see Settings and tap on the screen. Then, scroll up until you get to Restart Device. Tap on the screen, scroll up, & tap on Restart.
06-27-2023 07:39
06-27-2023 07:59
06-27-2023 07:59
