12-25-2021
11:36
15:06
DavideFitbit
12-25-2021
11:36
15:06
DavideFitbit
Ever since I changed the wake screen to manual, my battery won't last two days.
12-25-2021 15:06
12-25-2021 15:06
Hi, welcome to the Fitbit Community forums, @Pack21.
Thank you for sharing all this information about the trouble you've been having with your Charge 5.
The battery can last up to 7 days; because battery life is affected by use and other settings, actual results may vary.
Before considering other options, please make sure that you've followed the steps provided in this article. Some of the feature that can drain the battery more rapidly are:
In addition, try to perform a restart following the steps listed here below, this has been useful for other users experiencing something similar:
Hope this helps, I'll be around.
Best Answer12-25-2021 15:07
12-25-2021 15:07
Hello @Pack21
That seems strange. You’d think it would last longer…
It might be worth doing a Restart from your Charge 5 as that can often fix small problems.
Scroll down from the Clock Face until you get to Settings. Tap and then scroll down to Restart Device. Tap that and follow the instructions. It’s really quick and painless.
Hopefully that will help a bit.
12-31-2021 08:20
