08-25-2022
07:23
08:06
DavideFitbit
08-25-2022
07:23
08:06
DavideFitbit
My 2month old Charge 5 battery drained in less than 8 hours and sleep data not recoded. How to solve it? Really want to return this disappointing product but I don’t think I can after 2 month.
08-27-2022
08:06
07:41
08-27-2022
08:06
07:41
Hi, I appreciate all this information that you've shared about the inconvenience that you've been having with your Charge 5, @jtianen.
Before considering other options, please make sure that you've followed the steps provided in this article. In addition, try to perform a restart following the steps listed here below, this has been useful for other users experiencing something similar:
The battery can last up to 7 days; because battery life is affected by use and other settings, actual results may vary, but the battery shouldn't be draining only after one or two days. Keep in mind that some of the feature that can drain the battery more rapidly are:
The restart should also be helpful with the problem you mentioned to track sleep. In addition, there are some factors that may prevent your tracker from recording your sleep. Please make sure of the following:
Hope this helps, I'll be around.
