12-13-2021 00:01
12-13-2021 00:01
I found that if I charge my Charge 5 after it automatically shut down in low battery, it can last for a almost a week after recharging. But it only last for one day it I charge it while battery level below 20%.
How can I solve this issue?
Best Answer12-14-2021 03:30 - edited 12-15-2021 08:20
Hi, welcome to the Fitbit Community forums, @SunsetRunner.
Thank you for sharing all this information about the trouble you've been having with your Charge 5.
The battery can last up to 7 days; because battery life is affected by use and other settings, actual results may vary, but the battery shouldn't be draining only after one or two days.
Before considering other options, please make sure that you've followed the steps provided in this article. Some of the feature that can drain the battery more rapidly are:
In addition, try to perform a restart following the steps listed here below, this has been useful for other users experiencing something similar:
Hope this helps, I'll be around.
07:58
08:25
DavideFitbit
12-14-2021
07:58
08:25
DavideFitbit
I disable most of the function so the Charge 5 can last for a week if I charge it while it shut down by low battery level.
However, if I charge with battery level below 20%,the battery level will drop extremely fast, it can drop 30% in one night and the rest cannot last for the day.
I am happy that I only need to charge it once a week, every time I will charge it over two hours, evrn it showed 100% charged, I will keep on the charging for a while.
The problem bother me is as I mentioned, I think it might be improved in future with new firmware version. Please make an effort to solve this problem. Thank you!
Seems restarting during charging can be helpful
Best Answer12-15-2021 08:25
12-15-2021 08:25
@SunsetRunner Thank you for your reply and confirming that you had already tried the steps suggested.
The team of developers continues to work to improve performance with every firmware update. If you continue to experience this behavior with the battery draining too fast, even after you've exhausted all the steps recommended, I recommend that you get in touch with the Customer Support team for further assistance. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
They will let you know how to proceed or if there are any options available for you.
Have a good day.
