10-20-2023
09:01
05:28
CrisVillaFitbit
10-20-2023
09:01
05:28
CrisVillaFitbit
I am experiencing rapid battery usage on my Fitbit Charge 5. Rapid, as in consuming the battery in 3 hours after a full charge. Disappointed to read that 'a few' people are experiencing similar issues. I have reset the Fitbit (cleared user data), the 3 button reboot, the whole shebang. Disappointed especially after my wife's Charge 5 became bricked
Moderator edit: edited title to clarity
10-24-2023 05:31
10-24-2023 05:31
Hello, @JoeOnRoute66 Welcome to the community!
Thank you for your efforts with the situation you had with your Fitbit's battery. I was able to confirm you contacted support via chat and they were able to provide you with a solution, if you have any other questions or concerns, my best recommendation would be to contact them.
10-24-2023 18:27
10-24-2023 18:27
I am having the same problem. Today I charge my fit bit and with in an hour the battery is drained. My device is about a year and a half old.. Did the restart over and over again. Probably 8 times. What do I do. To fix this.
10-24-2023 18:28
10-24-2023 18:28
I am having the same problem. Today I charge my fit bit and with in an hour the battery is drained. My device is about a year and a half old.. Did the restart over and over again. Probably 8 times. What do I do. To fix this. I have recharged my fit bit 6 or 8 times in the last few hours. This is not okay
10-24-2023 20:26
10-24-2023 20:26
Please tell me what else we can do, as I am having the same issue and I have reset 4 times?
10-24-2023 20:37
10-24-2023 20:37
I'm also facing similar issue after firmware update. Please let me know how to fix it
10-25-2023 03:56
10-25-2023 03:56
Is there any way we can self diagnosis the Charge 5 ? Whether there is issue in battery?
