01-12-2022
09:15
05:10
DavideFitbit
01-12-2022
09:15
05:10
DavideFitbit
My battery life was a day and half at best. I have disabled heart monitoring which has improved it immensely. Does anything think Fitbit will find a fix for this, rather than loose a function?
05:09
11:09
01-13-2022
05:09
11:09
Welcome to the Fitbit Community forums, @Les64.
I appreciate all the information you've shared about this inconvenience you're experiencing with the Charge 5.
The battery of the Charge 5 can last up to 7 days; because battery life is affected by use and other settings, actual results may vary, but the battery shouldn't be draining only after one or two days.
Before considering other options, please make sure that you've followed the steps provided in this article. Keep in mind that some of the feature that can drain the battery more rapidly are:
In addition, please complete a restart procedure following the steps listed here below, this has been useful for other users experiencing something similar:
Hope this helps, I'll be around.
