08-10-2022 05:29
08-10-2022 05:29
Is it possible to calibrate/ edit the distance according to treadmill when fitbit shows wrong distance? I finished 5k run, but on my fitbit it shows 4,5k and i cant find any editing option like in my other sport apps before.
08-10-2022 06:03 - edited 08-10-2022 06:17
Assuming you are not holding hand rails part of time preventing some steps from being recognized, which is less likely on a run, you probably just need to adjust your stride length. A default is set, based on your physical data (height, age, etc) but you can adjust; plus might have different stride length on treadmill than regular running.
On phone app:
days of exercise tile > gear icon near top right > stride length > running stride length
As first estimate, I would just multiply the value there by 1.11 i.e. (5 / 4.5). Then you could fine-tune it as needed.
P.S. stride length is used to convert step count to distance when not using GPS.
