Calories
ANSWERED
Hiya can anyone explain why my fit bit says that I have burnt 1,324 calories even though I've only been wearing it 2 minutes!!! Thank you xx 😘
1 BEST ANSWER
Accepted Solutions
Hi @Lou123456
It is estimating your resting metabolism, that is, the calories you burn just be being alive (breathing, pumping blood, digesting food, making new cells etc), in terms of calories burned since midnight.  The later in the day, that higher the number will be even if you don't wear your fitbit. Of course, now that you've started to actually wear your fitbit, it will start adding the calories it thinks you are burning based on your movement and activity.  Hope that helps.
Scott | Baltimore MD
2 REPLIES 2
Hi @Lou123456
Thank you thats great I now understand
Get Outlook for Android<>
