01-04-2022
07:49
12:57
LizzyFitbit
01-04-2022
07:49
12:57
LizzyFitbit
I am using the adidas running app (before runtastic) and I had a hartrate monitor band around my chest from Polar, that was connected so my heartbeat could be registrated online in that app. (https://www.runtastic.com/ )
Now that I am using charge 5, there is no need anymore to wear that polar hartmonitor on my chest.
But It seems I cannot connect my charge 5 to my app. Is this a known issue ?
01-04-2022 12:54
01-04-2022 12:54
No Fitbit unfortunately can broadcast HR to a third part application.
01-04-2022 12:54
01-04-2022 12:54
01-04-2022 16:30 - edited 01-04-2022 17:30
Hello @PV1965
Just following your link and then clicking onto the list of partners, Fitbit doesn't seem to be listed at all, so probably doesn't support it:
This is an old thread I found about it, which may give you some ideas (or not).
From reading that, it sounds like maybe Runtastic are the ones to contact to ask them to allow integration.
There's also an a board that covers 3rd Party Integrations that might be useful to check out.
Sorry it's not the best news.
01-06-2022
03:12
12:40
LizzyFitbit
01-06-2022
03:12
12:40
LizzyFitbit
Thank you for the reply. That is a pity indeed, as I bought this to replace
my chest band heartbeat polar.
Moderator Edit: Personal info removed
03:13
12:41
LizzyFitbit
01-06-2022
03:13
12:41
LizzyFitbit
Thanks for the reply. I hoped that fitbit could expose its heartbeat
metrics online via bluetooth. But it is not the case.
Best Answer01-06-2022 03:14
01-06-2022 03:14
Hello @PV1965
You should edit your post to remove your personal information and phone number! If you’re quick you can catch it!
Best Answer01-09-2022 12:21
01-09-2022 12:21
Thanks for this advice, I just replied by email. Now I am struggling on how to edit dat particular reply. Do not find directly edit possibility. Can you advise me ?
Thank you very much
01-09-2022 12:29 - edited 01-09-2022 12:31
Hello @PV1965
I think only a moderator can do that now. I saw that @LizzyFitbit was online a moment ago and could maybe help with this.
01-09-2022 12:33
01-09-2022 12:33
Thanks, I will try to reach towards @LizzyFitbit .
01-10-2022
09:54
02:46
01-10-2022
09:54
02:46
Hi there, @PV1965. It's good to see you around. @SunsetRunner and @Wibby Thanks for your help.
@PV1965 I'm glad the suggestions shared by our members were of help. As they mentioned, currently it's not possible to integrate Fitbit with Adidas Running app. However, I'd encourage you to share this idea in the Feature Suggestions board. This is the best place to bring new ideas to our developers attention. I'm sure other members will support it by adding their votes, and you can always see our FAQs to learn more about this board.
By the way, thanks for the heads up and I edited your posts accordingly. Take in mind that you can click the three dots at the top right part of your post to edit it. In case you're having difficulties with that, you can always flag it down so any moderator can help you out.
01-13-2022 04:38
01-13-2022 04:38
Hi , thx for removing my personal data in my post. It was not possible for me to edit it via 3 dots at the right top corner.
Cheers.
01-16-2022
12:30
04:10
01-16-2022
12:30
04:10
Hi there, @PV1965.
You're welcome, thanks to you for your efforts. As mentioned before, if by any chance you want help with your post, you can flag it down as you did this time so we can help you out with that.
Hope you have a great week ahead! 😊
