10-26-2022
05:04
08:01
DavideFitbit
10-26-2022
05:04
08:01
DavideFitbit
Can I add Pilates as an exercise on my Charge 5?
08:00
04:29
10-27-2022
08:00
04:29
Hi, it's good to see you visiting the Community forums for the first time, @Berfit.
Thanks for sharing your inquiry about the Charge 5 and this activity.
Yes, I've confirmed with my Charge 5 that you can add Pilates as an exercise shortcut to have it directly on your device. To do so, you can follow the steps listed here. Keep in mind that you can have up to 6 activities as shortcuts on your device at the same time, so if you already have 6, you will need to remove one of them to add Pilates.
Hope this helps.
Best Answer10-27-2022 08:14
10-27-2022 08:14
11-17-2022
06:37
04:29
11-17-2022
06:37
04:29
