12-28-2022
13:35
08:39
12-28-2022
13:35
08:39
I just received my second Fitbit. How might I link the old and the new?
Best Answer12-28-2022 14:29
12-28-2022 14:29
If you mean keeping you history data, just use the same account to add the new device.
If you mean to use both devices, cannot do unless your previous one was a very old model.
12-28-2022 14:59
12-28-2022 14:59
Best Answer12-28-2022 15:25
12-28-2022 15:25
First, do a sync with old device to make sure all your data on it gets to the Fitbit database before removing that device.
Then same way you added first one. On phone app,
Profile pic > Set up a Device > Select your new device
It will say something like 'I see you already have a xxx connected. Do you want to replace this?' Answer yes, and it will remove old tracker and continue with setting up new one. On completion your data will look continuous with previous tracker. It any trouble setting up new one, might help to move old tracker (and any other bluetooth devices) to another room to avoid bluetooth interference.
