09-25-2021
09:17
12:48
SilviaFitbit
09-25-2021
09:17
12:48
SilviaFitbit
Is there a way to remove the Payments selection from the quick settings menu? I don't need it as I won't use Fitbit Pay and don't want to have to keep swiping past it every time I go into settings. I can't find a place in the Charge 5 or the iPhone app to turn it off, or even move it out of the way. I have even gone so far as to add a PIN to the wallet section of the phone app (which I'll forget since I won't use it) and could not find anything in there to turn this off either.
Any help would be appreciated.
09-29-2021 12:52
09-29-2021 12:52
@JeremyKrall Hi there. Thanks for the research and troubleshooting performed prior to posting.
I see where you're coming from. While the option to customize Charge 5 quick settings menu isn't available, you can always post your idea in our Feature Suggestion board, those are reviewed by our team and the status will change depending on Fitbit plans.
Hope to see your idea on the board. See you around.
