11-14-2021 11:02
11-14-2021 11:02
I was wondering would it harm my fitbit charge 5 if i washed dishes with it on?
11-14-2021 14:12
11-14-2021 14:12
@Elarra Check out the Charge 5 users manual here: https://help.fitbit.com/manuals/manual_charge_5_en_US.pdf
The relevant information is shown here:
There should not be a problem wearing it while washing dishes.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
11-14-2021 15:38
11-14-2021 15:38
Was not sure if the dawn dish soap would interfere with anything like the seals and such
11-14-2021 16:57
11-14-2021 16:57
@Elarra I suggest you just make sure to rinse it or wipe it clean to prevent any scum from drying on the sensors. I usually wipe mine clean every day and then use an alcohol wipe about once a week to clean off the back and the straps.
