Can't add yoga to my Charge 5 shortcuts
Since the app was updated, I can't add yoga to my exercises. I can add it manually, but it doesn't show when I search for it.
2 REPLIES 2
Hi there, @BeatBug. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 5.
Is yoga not showing up on your Charge 5 shortcuts? Please note that if you're referring to the Fitbit app alone, we did have some inconveniences lately but the issue has been solved. Would you mind trying to edit/add your yoga activity once again? I tested my yoga activity and indeed, I was able to edit my stats as usual.
Looking forward to hearing from you.
Thank you, I played around a bit more with the app, and i eventually found it!
