09-17-2023
01:52
04:05
09-17-2023
01:52
04:05
I can’t change screen wake from manual to auto. Tried in settings and scrolling down to screen wake and tapping. Not working, what can I do?
Best Answer09-18-2023 04:08
09-18-2023 04:08
Hi there, @Carole1957. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 5 and following the tips and recommendations provided by @RiekoC. I understand how you must be feeling.
As per the description of your post, it does seem that your Charge 5 is in sleep mode. When the sleep mode setting is on:
To turn it off, please see How do I navigate my Fitbit device?
Once the above has been done, please try once again to change the screen wake settings from manual to auto.
Best Answer09-17-2023 13:20
09-17-2023 13:20
Hello & welcome @Carole1957
The first thing I suggest trying is restarting your Charge 5, if you haven't already done so. You can do a restart from the device itself or by using the charging cord that came with your device. Click here for more detailed instructions: How to restart the Charge 5
Hopefully, after a restart you should be able to change the Screen Wake from Manual to Auto.
Let us know if this works for you.
09-18-2023 02:47
09-18-2023 02:47
09-18-2023 04:08
