06-24-2023
19:59
07:19
DavideFitbit
06-24-2023
19:59
07:19
DavideFitbit
Can't get x with red circles on Charge 5 to remove. Try press button 3 times etc
06-25-2023 07:17
06-25-2023 07:17
Hi, welcome back to the Community forums, @Missred123.
Thanks for all the details provided about this inconvenience with your Charge 5.
If you haven't done so already, please try the following steps that have been useful for other users:
06-25-2023 07:33
06-25-2023 07:33
06-25-2023 11:45
06-25-2023 11:45
Hello @Missred123
If the troubleshooting steps did not work for you, I suggest you contact Fitbit support, if you haven't already done so. They will likely walk you through the same troubleshooting steps. Once they confirm that the troubleshooting steps were not successful in returning your device to normal operation and, if it's still under warranty, they should send you an offer to replace the tracker/pebble or a discount on a different device. If your Charge 5 is out of warranty, they should offer a discount on a replacement. Note: the discount is on the full price, even if the device is on sale in the Fitbit store. Click here for: Fitbit support
07-20-2023 07:56
07-20-2023 07:56
@Missred123 Thank you for your reply.
Before considering other options, could you please confirm if you're still having the same problem and if you were able to try the steps suggested earlier.
