08-02-2023
11:17
03:34
08-02-2023
11:17
03:34
My charge 5 was showing the wrong time and date so I reset it and it still didn't work. I then deleted it from my device profile on the app and now the app will not work properly. It will not add the device back and just says thatbit cannot sync even though the screen pops up and says it's been found. I have done every it as instructed me to do and nothing works. Now my charge 5 is useless at the moment because it doesn't have the right date or time. Anyone else having this problem. I think it's an app issue but idk. I'm running on android 13 with a galaxy s20 fe 5g.
08-03-2023 03:37
08-03-2023 03:37
Hi there, @Nicole626. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Charge 5 before reaching out.
In addition to the steps you've done so far, please try the following steps in the order listed (even if some of them you've tried already):
With the steps above, what I want you to do is to pair your Charge 5 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
08-03-2023 03:37
08-03-2023 03:37
