03-14-2023
05:59
07:08
03-14-2023
05:59
07:08
New to Fitbit - Recently got a Charge 5. I had Sleep Mode on manual but nothing showed in the a.m. Now switched to Auto but bottom shows 'off'. It says to sync in the a.m but do not understand? Have I-phone. MANY THANKS!
Best Answer03-14-2023 07:10 - edited 06-03-2023 11:24
Hi there, @1NJ. Welcome to the Community Forums. Thanks for the details provided in your post about the inconvenience with your Charge 5.
I recommend considering the following in order to get sleep stages:
For more information, see What should I know about Fitbit sleep stages?
Have you tried disabling the sleep mode? When sleep mode is on:
Sleep mode turns off automatically when you set a sleep schedule. For more information, see Settings app.
For more information, see How do I navigate my Fitbit device?
Best Answer03-14-2023 07:13 - edited 03-14-2023 07:14
"Sleep Mode" has nothing to do with detecting sleep. It is just for turning off certain things that might interrupt your sleep such as notifications, dims your screen, and prevent screen turning on with wrist turn.
You don't have to use Sleep Mode to get sleep results. But if you do use it, there are 2 ways.
(1) In Quick Settings, you can turn it on when you go to bed, then turn it off when you get up.
(2) Or if you keep a regular schedule, in full Settings, you can set a schedule to automatically turn it on and off at set times and then have it happen automatically with no more interaction.
