12-17-2021
06:48
14:59
DavideFitbit
12-17-2021
06:48
14:59
DavideFitbit
woke up this morning and discovered that I had taken 30,000 steps and 31 miles in my sleep.
12-18-2021
14:58
10:40
12-18-2021
14:58
10:40
Hi, welcome back to the Fitbit Community forums, @itgrey.
Thank you for sharing this information about the inconvenience you experienced with the Charge 5.
Before considering other options, I recommend that you complete a restart procedure using the charging cable:
If you already tried the restart and you continue to experience the same problem, I recommend that you get in touch with the Customer Support team for further assistance with this. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
I'll be around.
01-08-2022 00:13
01-08-2022 00:13
I have also done 19000 steps in 15 minutes, whilst asleep!
01-08-2022 04:45 - edited 01-08-2022 04:45
It sounds to me like you have some extremely active dreams! Maybe you’re so focused on health you were running marathons in your sleep? 😃
Stay healthy! 🙂
01-08-2022 13:14
01-20-2022
10:30
10:40
01-20-2022
10:30
10:40
03-18-2022 16:37
03-18-2022 16:37
Not to try to outdo you, but at 4am. last night while sleeping I completed 100,000 steps! Wow! I know I'm not a sleepwalker, but if I was the carpet would be wore out at that pace. I had another night where I logged 50,000 steps. The unfortunate part is trying to fix it. The only thing I've found you can do to offset all of those steps is to create an activity, "Driving" in your Logs section under Activities. If you know the time, just put the duration for 5 min. and it will take all of those steps away. Got that from this forum one day. Should be easier to edit out erroneous steps like that than have to create an activity to offset them. Anyone at Fitbit listening?
03-24-2022
11:56
10:40
03-24-2022
11:56
10:40
@6TJS6 Thank you for your reply and for sharing your experience with this.
The amount of steps you mentioned is too high to be caused by a fan, by any movements at night or other external factors that often result in some users seeing extra steps recorded when waking up. In this case, I do recommend that you get in touch with the Customer Support team for further assistance. Click here to get connected.
See you around.
