Charge 5, Android phone & No phone notifications
ANSWERED
Hi there,
My Charge 5 has stopped receiving phone notifications from my Android (v12).
All the settings are correct in both the app and the phone settings and a test notification works.
I've reset both devices multiple times and still get a red notification error message at the top of the screen about a phone restart being required.
Please can someone help me? 😕
1 BEST ANSWER
Accepted Solutions
@Beckie_Boo Please check whether or not the Fitbit app is allowed to run in the background on your phone. To do so, tap and hold Fitbit app's icon until a popup menu appears. Tap on "(i)" in the upper right corner of this menu. Then tap on "Battery" and select "Unrestricted".
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Charge 6, Versa 4, Aria, Aria 2, Pixel 4a, Pixel 7
7 REPLIES 7
@Beckie_Boo Sad to hear that your Charge 5 isn't working as expected.
If the test notification works, the connection between the Fitbit app and your device should be fine. Do you get notifications on the phone itself?
Stefan
Hi @Talahthas ,
Yes, the notifications work fine on my phone... It just doesn't send them through to the Fitbit.
Stefan
Changing the battery to be unrestricted seemed to do the trick... Thank you so much @Talahthas! 😊
@Beckie_Boo Glad I could help you. Thanks for your feedback!
Stefan
Hi I am having the same problem
Battery usage is unrestricted and still not sending notifications
Shelly
@Shellydw Welcome to the Fitbit community!
Could you successfully send the test notification provided by the Fitbit app?
Stefan
