03-28-2023
20:44
05:18
DavideFitbit
03-28-2023
20:44
05:18
DavideFitbit
I recently downloaded the latest Charge 5 software version to my Charge 5 and ever since the battery runs out every day instead of the normal 7/10 days is anyone else experiencing this problem and know how to fix it . The Fitbit is only 14 months old ?
05:17
11:32
03-29-2023
05:17
11:32
Hi, it's good to see you visiting the community forums for the first time, @Doctorw.
I appreciate all this information that you've shared about the inconvenience with your Charge 5.
There are a few features that would make the battery drain faster than usual, even in one day. Some of these features are:
If this doesn't apply to you, another step that has been helpful for other users having battery draining problems is the three pulse restart procedure using the charging cable:
In general, it is recommended to follow the recommendations listed in this article to improve or extend battery life.
04-25-2023 23:36
04-25-2023 23:36
Ive tried all these options but still having issues , ive also lost the zone minutes on the app . Have i turned something off by accident trying the above choices
Best Answer04-26-2023 06:19
04-26-2023 06:19
Hi,
I'm experiencing the same thing. Since today the battery of my fitbit charge 5 is empty within 1 day. Before my battery lasts 6 to 7 days. How is this possible? My fitbit is not even 1 year old. Bought August 2022
Regards,
Priscilla
04-26-2023 14:32
04-26-2023 14:32
I have a similar issue. The battery discharges after only 1 hour 😪
04-26-2023 18:29
04-26-2023 18:29
Same issue, tried everything keeps dying every 4-6 hours. Only 6 months old as well. Super annoying.
04-27-2023 23:07
04-27-2023 23:07
Hello!
Many people are reporting the same issue since yesterday/last update...
They messed up something and should figure out how to fix it ASAP...
05-03-2023 12:15
05-03-2023 12:15
Anything else I can try, almost to the point of throwing it away and getting a different tracker.
05-03-2023 12:31
05-03-2023 12:31
Hello,
I have tried this and my Fitbit still won’t hold a charge for more than 12 hours
Best Answer05-04-2023 10:33
05-04-2023 10:33
Hi everyone, I appreciate all the feedback that you've shared so far about this issue.
Thank you for confirming that you already tried a few troubleshooting steps shared in the forums and that you continue to have this problem with your Charge 5. If you're new to this thread, please make sure to exhaust all the troubleshooting options listed here.
If you already tried all the steps shared in the forums, I recommend that you get in touch with the Customer Support team for further assistance with this. You can click here to get connected and I'm sure they will let you know how to proceed.
