01-14-2025
04:40
06:22
MarioSFitbit
01-14-2025
04:40
06:22
MarioSFitbit
Please can you explain why my charge 5 shows charging notification at 25% but I never get an email notification until my charge 5 is at 15%.
Thanks.
Hi @Robin74. Welcome to the community forums.
Thank you for sharing the inquiry regarding your Charge 5.
Please, try to perform the following troubleshooting steps:
In addition, try to toggle off and on the notifications on the Fitbit app.
Beside that, confirm that your Charge 5 is syncing correctly and your Fitbit app is up to date.
01-16-2025
09:05
14:44
ManuFitbit
01-16-2025
09:05
14:44
ManuFitbit
Thank you very much for the advice, I followed your instructions and will now wait untill my charge 5 needs charging probably next Tuesday, I'll let you know if it's worked. Thanks again.
Further to my earlier reply, my charge 5 now needs charging, I followed all your suggestions, but unfortunately the battery notifications are still the same.
I have had three Fitbit trackers since 2016, a Alta, charge 3 and my present one a Charge 5, and have always had the problem.
I have also made sure the tracker is syncing correctly.
Thanks
