Charge 5 - Doesn't charge or turn on
charge 5 does not charge or turn on
Moderator edit - updated subject for clarity
5 REPLIES 5
Hi @rv23 and warm welcome to the forums.
I appreciate your message, and I'm sorry to hear that your Charge 5 is not charging or turning on.
This is definitely not the experience we want for our customers, and I understand your feelings about this situation.
Could you please confirm if you can see the lights on the back of the pebble?
Please, try to restart your device as explained here: How do I restart my Fitbit device?
I also suggest you to verify the tips listed in the following help article: Why isn't my Fitbit device's battery charging?
Visit our Discussions board where you can share your experiences, meet people and create new topics.Si ma réponse vous a plu, merci de me féliciter. Si votre question a trouvé une réponse, acceptez la solution.If you liked my answer, give me a Kudo. If your question was answered, accept the solution.FR-EN-SPA.
thers's no lights on the back of the pebble
I’m having same issue had 88% power. Then I noticed after washing up the screen is black. It doesn’t do anything, unresponsive at first to charging, after a while and multiple attempts at reset with usb I got a buzz. However screen still black. Is there a software issue? I’m going it fixed over night.
@rv23 I was having a similar problem with my Fitbit this weekend.  I  cleaned the contacts with a damp Q-tip. When that didn't work I reset my Fitbit.  There is a small button on the USB portion of the charging cable.  Press the button three times with about a second in between presses.  Your fitbit should reset in about 10 seconds.  That worked for me today.
i tried that multiple times didnt work
