01-12-2023
13:01
07:51
DavideFitbit
01-12-2023
13:01
07:51
DavideFitbit
The ECG on my fit bit is not working. I’m trying to use it. It comes up and says error. Please re-open the application. I’ve done that multiple times on multiple days and it is not working.
Hi, welcome to the Fitbit Community forums, @Lindyemma.
Thanks for sharing these details about the issue you're experiencing with the Charge 5.
If you haven't done so already, please try the following steps that have been useful for other users experiencing something similar:
Hope this helps, I'll be around.
01-13-2023
16:10
10:22
DavideFitbit
01-13-2023
16:10
10:22
DavideFitbit
I have the same problème with my Fitbit Charge 5 , IT Say that he dont find m'y phone, for the ECG . Is it because i have a Huawei?
Moderator edit: format
Welcome to the Fitbit Community forums, @SylvieBoul.
Thank you for sharing that you've been having the same inconvenience with your Charge 5.
I've been informed that you already contacted the Customer Support team for further assistance with this and it seems they've shared some instructions with you. In this case, they will let you know how to proceed.
Best AnswerI’m having the same problem , I uninstalled and restarted and it still says Error etc. While the 5 may seem higher quality, I found my 4 to be more sensitive and reliable. This one just charges faster big deal.
@kesweet Thanks for sharing that you've been experiencing a similar problem and for all your feedback about the Charge 5.
If you haven't done so already, please try the following steps as well and let me know if the issue persists:
