12-21-2023 08:32
                                          Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              12-21-2023 08:32
We’re excited to announce that a firmware update version 194.91 for Charge 5 is now available! If you installed it, let us know what you think!
WHAT’S NEW AND FIXED
Full release notes can be found here.
HOW DO I UPDATE?
See How do I update my Fitbit device? for step by step instructions for updating your Charge 5. If you run into difficulty updating, review these Why can't I update my Fitbit device?
We’re interested in hearing your feedback on this update! Let us know what you like! If you encounter unexpected behavior during or after your update, please post the details below.
02-06-2024 16:46
02-06-2024 16:46
I have the same problems as described by you.
02-06-2024 20:08
02-06-2024 20:08
My Charge 5 is on 194.91. Until Thursday, it used to last multiple consecutive days without a charge, with always-on display.
Now, I charge it to 100%, put it on, and it's dead within an hour.
02-06-2024 23:30
02-06-2024 23:30
Well mine is not even on the latest firmware and the battery drain started happening just coincidence i might add just after warranty expired. But I do kind of understand that battery degradation happens and mine is showing that (everytime you plug into charger it shows a different % of charge 8%, %14, %26 !!).
Well as am out of warranty suppose I might as well try changing the battery (am guessing that one the battery is disconnected and the hardware fully discharges the firmware will reset). And thus when charging again will read the correct % from battery.
Worth a go ? Has anyone replaced the battery successfully?
02-07-2024 01:52
02-07-2024 01:52
Can’t get it to upload this morning updated software and still no syncing
02-07-2024 02:46
02-07-2024 10:42
02-07-2024 10:42
Here's another article about the issues with Charge 5 https://www.notebookcheck.net/Fitbit-New-smartwatch-update-provides-new-functions-but-makes-devices-...
02-07-2024 15:27
02-07-2024 15:27
has there been any change?
 Best Answer02-07-2024 16:29
02-07-2024 16:29
Can you try it putting the first part of the email address,, a space, domain name, space, extension???
02-07-2024 16:39
02-07-2024 16:39
I have a working Charge 5 that didn't go through any of these updates and is on 57. blah blah. Should I try to update it? Google will try to break it anyway.
02-07-2024 17:36
02-07-2024 17:36
I should have known better not to update.
I didn't update the thing since I bought it and never had an issue. But a week after a firmware update, the display turned black. It is still working and syncs- just without the display.
Is there a way to roll back to a previous installed firmware?
02-08-2024 02:50
02-08-2024 02:50
Same here!!!!
 Best Answer02-08-2024 03:48
02-08-2024 03:48
Is there anyway to force the firmware update or can it be side loaded from the app ? Can the latest firmware be pushed out to my charge ? (Am not on the latest firmware)
 Best Answer02-08-2024 04:31 - edited 02-08-2024 04:35
I don't know the thing is that there's no way for me to even update to the new one bc no update banner appears. I contacted Fitbit support and they said it's policy that you can't get 50% off a new Fitbit device. They told me I have to update from 4.9 to 4.10 on the app.
02-08-2024 05:53
02-08-2024 05:53
Add me to the long list of ex-Fitbit users. My charge five buzzed wildly a few minutes when I plugged it in around December 5, I can only assume it was being updated, then it was dead. It has remained dead, nothing I did could revive it.
I have decided to scrap the device, even though it was barely a year old, and even though I have bought 4-5 Fitbit products since 2015. It's clear to me that my Fitbit chapter has come to an end. My new Garmin is doing well.
02-08-2024 06:35
                              02-08-2024 06:35
Welcome back to the community, @CHCHAN.
Thanks for letting me know about the exercises you'd like to be in the exercise app using your Charge 5.
My best recommendation would be for you to post this idea in the Product Feedback board in the community, since this section is regularly monitored by the team of developers. Make sure to post your idea including as many details as possible.
 Best Answer02-08-2024 06:48
                              02-08-2024 06:48
Welcome, @RJayneC, to the community.
Thanks for letting me know about this situation with your Charge 5 after the update.
Can you let me know if your Charge 5 vibrates when you connect it to the charger? Also, does the green lights in the back of it are on?
This will help me further investigate on this, I recommend you to do the following too:
- In the Fitbit app, touch your profile picture, touch your Fitbit device and click 'Sync Now'. This will help you synchronize it.
- Restart your device by following the steps here.
- After this, change the clock face of your Charge 5. In the Fitbit app, you can access the image of your profile and the image of your Fitbit device, touch the gallery and the screen and click on the clock face, preferably one of Fitbit and install.
		11:31
		11:49
			JuanFitbit
		02-08-2024
		11:31
		11:49
			JuanFitbit
crisvillafitbit  this is the second time that i noticed you posting "my best recommendation would be for you to post this idea in the product feedback board in the community, since this section is regularly monitored by the team of developers. make sure to post your idea including as many details as possible."So my question is: Why are is the team of developers not monitoring this section?
Moderator edit: format
02-08-2024 15:12
02-08-2024 15:12
No really sure mine updated or not but I noticed today around 3:30 this afternoon my Fitbit started malfunctioning. It won't turn on the face when I tap on it, it occasionally flashes the Fitbit symbol, and when it does turn on it is not tracking my steps accurately. This is my second Fitbit, my first one also malfunctioned after an update. I use my Fitbit all the time and this is getting frustrating. I am not sure if I want to get another one if they are just going to keep malfunctioning after every update.
02-08-2024 16:27 - edited 02-08-2024 16:31
If it's still syncing to your phone, you can check the firmware version.
Tap the device icon in the upper left (the one that shows device charge %), then tap the "Charge 5" under Devices.
If Firmware Version ends in 194.91 it's updated to the latest version.
Mine's been running fine on 194.91, though from this thread it's clear that many people have run into problems with it. I saw one glitch on HR measurement, and one on logging sleep, IIRC, in the first day or two, working well since then. Battery use is the same as before the upgrade (recharge needed once per week - I have most optional items like SPO2, and most Notifications, turned off).
02-08-2024 16:43
02-08-2024 16:43
Not syncing anymore and I tried restarting it, changing the clock face, ... I have pretty well given up on it.
