12-04-2022 02:58
12-04-2022 02:58
Hi,
I replaced my Inspire HR with a Charge 5 because occasionally the watch was loosing the connection to my phone when I was running, and bits of the track were missing, I figured that the Charge 5 with the built in GPS would be more robust.
So far I've found that
I'm finding that is's miss-calculating my runs - yesterday I did a longer loop than the previous time - I did the same loop, but added in some additional pieces. The total length of the run was less - this means that all of the pace data is junk, and it means that if I try to compare how I'm doing running up some hills I cant.
I'm hugely dissappointed with the Charge 5 performance am I the only person who finds the GPS tracking really inaccurate / useless?
12-07-2022
07:39
06:17
12-07-2022
07:39
06:17
Hi, welcome to the Fitbit Community forums, @Peter-S.
Thank you for sharing this information about the trouble you've been experiencing with your Charge 5.
If you continue to experience the same behavior and your GPS is getting disconnected, make sure to try following the steps listed in this article to complete a restart using the charging cable, as this has been useful for other users experiencing something similar.
If the GPS is getting disconnected during your activity, the Charge 5 may track different information for the the distance. Before considering other options, make sure to follow the steps suggested in this article as well.
All devices with GPS sensors require a direct path to GPS satellites to calculate location. A weak GPS signal might affect the accuracy of your route and other activity data. Your device uses your step count to calculate distance until it finds a signal, so the total distance calculated for a workout may be slightly less accurate when GPS isn't available for the entire time. In particular, please make sure of the following:
Thanks again for all the feedback and comments that you've provided so far. The team continues to work to improve the Fitbit experience and your feedback is big part of that process.
Best Answer12-20-2022 01:58
12-20-2022 01:58
Hi,
So I've been concucting an experiment over the last couple of weeks (was interrupted by some freezing weather. I ran the same route three times, twice with GPS set to "Dynamic" and the last time with it set to "Built-in".
Run 1
GPS setting = Dynamic
Distance = 6.29 km
Steps = 5,838
Time = 34:23 mins
Pace = 5'24"
Run 2
Distance = 6.06 km
Steps = 5,791
Time = 34:14
Pace = 5'35"
Run 3
GPS setting = Built in
Distance = 7.1 km
Steps = 5,840
Time = 35:07 mins
Pace = 4'54"
As you can see the distance with the built in GPS is a long way from the others. Map my run puts the actual distance as 6.11 km.
Looking at the gps tracks, there's a lot of difference - I'm going to try and find a way to compare them.
Does anyone else have issues with built in GPS / GPS on the Charge 5?
Thanks,
Best Answer12-20-2022 02:07
12-20-2022 02:07
Hi DavideFitbit, sorry for not seeing your response sooner - I wasn't able to run much over the last weeks due to Icy conditions. My problem isn't with the GPS disconnecting - it's just that the GPS seems to be very inaccurate.
I've tried working through the reset process and it meant that the GPS does work now, but very inaccurately (I just added a post where I compared a number of runs).
Thanks
Best Answer02-04-2023 08:36
02-04-2023 08:36
You are not the only one. When using the built-in GPS, my tracks are much less accurate than what my partner gets on the same run with Garmin. I don't understand why, since Charge 5 advertises using the same GPS + GLONASS sensors as Garmin, but I guess I'll switch.
