12-13-2022
08:34
05:42
12-13-2022
08:34
05:42
Hi, welcome to the Community forums, @Aquasky.
Thank you for your inquiry regarding the option to remove the notifications option from the watch.
As you mentioned earlier, when you swipe right from the main clock screen, you immediately see the notifications and then you see the exercise shortcuts if you swipe right again. Unfortunately it's not possible for the moment to customize or rearrange the order of the apps on the screen.
I would recommend that you vote for this idea posted in the Feature Suggestion board of the Community, since this section is regularly monitored by the team of developers: Able to customize order of apps/stats on Charge 5.
If you'd like to see an option to remove apps completely from the device, you can also post an idea separately. Make sure to post your idea including as many details as possible. Some apps can be uninstalled, but other default apps like Notifications, can't be removed from the device.
Hope this helps.
