02-13-2023
16:48
05:11
DavideFitbit
02-13-2023
16:48
05:11
DavideFitbit
There is another thread with a bunch of that was marked "resolved" even though this issue is not resolved. Many people buy this watch for it's SUICA functionality, and currently it is unresponsive at train ticket gates. Please allow users to roll back the update or fix this issue!!
The issue is only present as of the latest firmware update on the charge 5. If you are not going to fix the issue, just re-release the old firmware as an update?
Many in the other thread have already switched to Garmin watches.
Best Answer02-14-2023 05:11
02-14-2023 05:11
Welcome to the Fitbit Community forums, @Stalzer.
Thanks for sharing all your feedback and that you've been having this inconvenience with your Charge 5 and Suica functionality.
Could you please provide a few more details about this issue? This will help us understand the specific problem that you're experiencing and find out if there are any steps that could be helpful.
Best Answer02-17-2023 03:15
02-17-2023 03:15
Yes the IC card function on the charge 5 is currently unresponsive when using it at train stations. It used to quickly scan when passing through the ticket booth, but now it sometimes won't scan no matter how many times you try. Many people are having this issue
03-02-2023 05:03
03-02-2023 05:03
@Stalzer Thanks for confirming that you've been having a similar issue with your Charge 5 and Suica.
Before considering other options, could you please confirm if you already followed all the recommendations listed in this article?
In addition, please try restarting your device using the charging cable and check if you continue to have the same problem.
