08-05-2022 12:38
08-05-2022 12:38
Screen blank - shows 24 percent battery life left. 1 month old. Simply stopped working while on a nature hike - no water…any ideas? Will place on charger when I get back home to see if that “resets” anything…thanks
Best Answer08-05-2022 12:56
08-05-2022 12:56
Hi Sparn16,
I'll tell you about my recent troubleshooting with fitbit which got screen responsive and my watch to work again so you can do it without calling.
First, try to sync your device in the app.
Secondly, reset the device. To do this, at the end of the charging cable where the Fitbit charging cable plugs into the USB charging block, you'll see a reset button. WIth the phone on the charger, press the button 3 times with a 1 second gap between the pushes. Check your screen and you'll likely see the Fitbit image come across it and then the battery charging box.
I hope it works for you. Good luck!
Sarah's Hubs, Rick (she just tells me if its broken...lol)
08-05-2022 13:56
08-05-2022 13:56
Thanks
