02-13-2025 01:47 - edited 02-18-2025 01:17
Hello,
Yesterday I was having problems with my Charge 5 for payments via Google Wallet.
On the forums, it was suggested to remove and re-add the card.
Well I removed the card, and now I cannot add any new ones. Every time I try to add a card, the request times out during the "Processing card details" step.
The card works in my Google wallet app instead. And I tried also with a second new card but I get the same error. And I already checked, my bank is in the list of supported banks for my country.
What else can I do? It is a problem on Fitbit side?
Best Answer02-17-2025 01:00
02-17-2025 01:00
As an update, I tried with multiple cards from the same/another bank, plus my Wise card (which is definitely supported). No luck, still getting the same timeout error.
Last week I contacted the Google support but did not receive much help other than 'try to reboot the devices and turn off/on the bluetooth'. Which did not work.
This is quite annoying as I was using the feature a lot!
