01-04-2022 04:47
01-04-2022 04:47
Hi there,
I am a new user of the Charge 5, unfortunately the sport I practice the most, (indoor) climbing, is not available in the list of activities.
During a climbing session tonight, I have tried using the 'Outdoor sport' activity, which has tracked my HR but also my GPS position which is really useless for climbing.
Has anyone of you found what built-in activity is best to track climbing session ?
Thanks to the community ! And HNY !
Z
01-04-2022 04:54
01-04-2022 04:54
Hello @Zicinparis
It's probably easiest to use the generic 'Workout' as your shortcut instead as it won't use GPS. When you go to your App later you can change the name by tapping on it, then the arrow on the top right for Categorize Exercise and then start typing an exercise in the search box. I couldn't find Climbing or Bouldering, but could find Rock Climbing, if that's any good for you.
I hope that helps a bit.
01-04-2022 05:04
01-04-2022 05:04
Thanks @Wibby this makes good sense !!
I didn't know about categorizing the activity later, I'll try this !
Thanks again ! 😉
