12-01-2022 09:28 - last edited on 12-02-2022 07:08 by DavideFitbit
My Charge 5 will no longer charge (anyone else see the irony here). I have cleaned the contacts on both the Fitbit and the charging cradle/cable. I have tried several different USB power adapters and yet the Charge 5 does not take a charge. It is still running, but the battery is down to just 7%. So it won't be long before it dies. Any troubleshooting suggestions? Unfortunately, I do not know anyone with a Charge 5 to be able to try their charger.
07-01-2023 11:46
07-01-2023 11:46
Mine is having the same problem. While charging it stays with the logo screen, tried different methods and restarting and it just isn’t working. I’ve been using it for 7 months now.
07-01-2023 13:55
07-01-2023 13:55
07-01-2023 17:44 - last edited on 07-12-2023 08:28 by DavideFitbit
Same! It's so frustrating. I've been messing with it on and off all day and nothing is working.
It's also really odd to me that there are several of us having exactly the same problem on the same day.
07-02-2023 01:07 - last edited on 07-23-2023 09:19 by DavideFitbit
Exactly the same problem here. Recently charged it, now the screen is black and it says in the app that the battery is dead. Will not charge. Tried the reset button on the charger, did nothing. Same day, same problem. Maybe it has something to do with the firmware update that is being enrolled these days?
I thik i actually fixed it. I deleted the app from my phone an re-installed it. Suddenly it connected to the watch again and syncronized. The battery is now at 17%. Fingers crossed this fixed the problem
07-02-2023 02:14
07-02-2023 02:14
07-02-2023 02:32 - edited 07-02-2023 02:36
Nope. The battery charged up to 100%, and syncronized fine, but when i took it out of the charger it went straight back to 0%. Very frustrating. But now the update firmware button is pink and functional. When it is completely recharged i will try installing the update, maybe that will help...
07-02-2023 08:46
07-02-2023 08:46
I Sprint over an hour in live chat with Fitbit. tried all of the ways they suggested to restart and reset the Charge 5.. no dice. I purchased the Fitbit Thru Amazon. I tried repeatedly to send them the invoice for the purchase.. no dice. Left everything alone for 3 days and trying again this morning. So far… nothing.
what else can i do.??
07-02-2023 09:10
07-02-2023 09:10
07-02-2023 15:00
07-02-2023 15:00
Hello! I am having the same issue. I followed the steps about using the button on the charger and mine just stays black—zero signs of life. Is there something else I can do? Thank you!
07-02-2023 15:40
07-02-2023 15:40
07-12-2023 08:43 - edited 07-12-2023 08:44
Hi everyone, thank you for all the comments and feedback that you've shared about this inconvenience. I'm sorry to see that you continue to have the same problem to charge your device.
If you continue to have the same problem and you already tried the recommendations mentioned earlier to restart using the charging cable and the other steps mentioned in this article, I do recommend that get in touch with the Customer Support team so they can provide you with the next steps.
07-12-2023 09:03
07-12-2023 09:03
07-12-2023 09:22
07-12-2023 09:22
Well sad to say but I now have the same problem - completely dead with no charging at all. Of course I'm outside the warranty, and since this was given as a gift to me it's very doubtful that Fitbit will do anything about it.
I've tried all the restart options - on the charging cable was my only option now - and still no-go. It was already having issues like seemingly everyone else where the battery was dying faster & faster everyday. I wound up having to charge the darn thing at least 3 times a day. I left it overnight charging and it worked fine for about 5 mins after taking it off the charger. Then it black-screened and has been dead ever since.
Looks like someone wasted a decent amount of money on a junk product that only lasted 18 months.
07-12-2023 09:27
07-12-2023 09:27
07-12-2023 10:18
07-12-2023 10:18
It is indeed ironic. Customer service got my charge five started again and once I get it fully charged, the charge lasted less than two hours. Their remedy was to give me a 35% discount on a new Fitbit but why would I buy another one when this one lasted just over a year? I think I’ll do my homework and buy a different brand.
07-12-2023 11:03
07-12-2023 11:03
07-21-2023 09:11
07-21-2023 09:11
Same here! I’ve tried everything and my Charge 5 battery charges to 99% then when I take it off the charger it goes down to 1%. Contacted customer service and all they gave me was a coupon for 35% off a new one. I’ve only had it a little over a year. Looks like this is happening to a lot of people and it’s Fitbit’s fault. Not buying another one!
07-22-2023 08:27
07-22-2023 08:27
I have cleaned the fitbit and the cable prongs. I have tried two adapters as well as the USB port on my computer. I have pressed the cable button 3 times for 1 second each (the fitbit symbol showed up with a slight vibration but it just said that it was critical to charge the battery). Now my battery is completely dead. What other options do I have?
07-28-2023 10:58
07-28-2023 10:58
This solution does not work. This is my 3rd Fitbit in 6 years. They should last longer.
WILL NOT BUY AGAIN (was a happy customer).
07-28-2023 11:07
07-28-2023 11:07
