04-27-2023
13:34
07:10
DavideFitbit
04-27-2023
13:34
07:10
DavideFitbit
Exactly at 180 days by Charge 5 went black. I can charge it and it will show when the battery is full but then will drain completely within 15 minutes. I followed every troubleshooting option including cleaning and changing wrist bands and disabling features. Has anyone else experienced this recently? My Fitbits used to last at least 3 years so this is a huge disappointment.
Best Answer04-27-2023 16:29
04-27-2023 16:29
Yes, I received an automated update this morning and now the battery only last 1.5 hours. I chatted with tech support earlier. They said reboot it (click the little button on the charger 3 times in 8 seconds) charge to full and monitor results.
16:55
07:11
DavideFitbit
04-27-2023
16:55
07:11
DavideFitbit
I have tried that but will do it again and see.
29 min after fully charging my battery is at 40% and I have just been sitting still. I guess I will have to call someone at Fitbit.
Best Answer04-27-2023 18:10
04-27-2023 18:10
Best Answer04-27-2023 19:01
04-27-2023 19:01
Same for me.
07:10
06:47
04-28-2023
07:10
06:47
Hi everyone, thanks for sharing that you've been having the same inconvenience with your Charge 5 and that you already tried a few steps.
It seems that you already tried all the troubleshooting options shared in the community to try to resolve this problem. As you mentioned earlier, for battery draining issues it is usually recommended to follow these steps and to try restarting the device using the charging cable.
If you continue to have the same problem, I do recommend that you get in touch with the Customer Support team for further assistance with this. They will let you know how to proceed. Click here to get connected.
Best Answer04-28-2023 15:10
04-28-2023 15:10
In my case they are sending a new 5. I was hoping they could just send another update to fix it. No, it is not fixable. Great customer service!!!
Best Answer05-10-2023 07:27
05-10-2023 07:27
@Absofsteel Thanks for sharing your experience! I'm sorry to see that it wasn't possible to resolve the problem, but it's good to know that you've received a replacement device.
Best Answer05-10-2023 09:48
05-10-2023 09:48
Wish I knew what the criteria is for replacement. Support had me do a hard restart again, created a case number but didn't disclose to me that I had to respond within a day or 2 if it did not work so now they closed my case number and will not respond to any further emails. So disappointed.
