01-01-2023 23:10
01-01-2023 23:10
Not the first time this has happened. Happened exactly one month ago as well (dec contacted support and they basically walked me through resetting my Fitbit.
Planned alarms do not go off. When putting in a new alarm, it automatically defaults to tomorrow, and you just know it's not going to go off again.
Deleting alarms and readding doesn't help.
Only solution is resetting the Fitbit, but honestly I'm quite annoyed a +€100 smart watch isn't able to wake me. Should I buy a €10 alarm clock that's more reliable?
I managed to wake up in time today, but last time I was late for work and got written up, simply because my alarm didn't go off.
It's not the first time this has happened, please just fix it???
01-01-2023 23:53 - edited 01-01-2023 23:55
Happened to me also. In my case, the daily alarm switches itself off and I have to switch it on again. If you have the same cause as me, then I noticed that after it has switched itself off and you've switched it back on twice, it stays on and doesn't break again. At least, not yet... The first breakage was next day, and the second after several days. Be sure that all you do is to turn it back on when it fails, else the cycle restarts. Hope this helps and agree it is a complete nonsense that you can't rely on a watch alarm to go off as scheduled!
Best Answer01-02-2023 02:26
01-02-2023 02:26
This happened to me before at least a couple of times before, which is already quite annoying if the alarm is not reliable, but restarting solved it. Form the last week, it just does not work, not even restarting which I have done multiple times. This is just useless…
Best Answer01-02-2023 10:25
01-02-2023 10:25
LOL spoke too soon! Just checked to make sure the alarm is all set for tomorrow, and discovered it has turned itself off again. When I went to switch it back on, it was set to go off for a single day. I had to change it to back every day. If you switch off an alarm manually, it retains whatever setting it had, so this is unusual behaviour. A clue maybe? Dunno.
