Charge 5 alarm not working
The biggest dissatisfaction with Charge 5 is the alarm feature. My alarm just stopped working I reset the alarm and then reset device turned Bluetooth on and off still not working. No support help
1 REPLY 1
Hi, welcome to the Fitbit Community forums, @Time2022.
Thank you for sharing all your feedback and that you've been experiencing this inconvenience with your Charge 5.
If you haven't done so already, I recommend that you try restarting the device using the three pulse restart method mentioned here below, instead of the restart option found on the Charge 5 itself:
  1. Connect your device to the charging cable. For instructions, see How do I charge my Fitbit device?
  2. Press the button located on the flat end of the charger 3 times (end of the USB cable), pausing for 1 second between presses. Then wait 10 seconds or until the Fitbit logo appears.
In addition, please try removing and re-adding the alarm following these steps
I'll be around.
