01-19-2023 08:57
01-19-2023 08:57
First my Charge 5 would not synch. So I "removed" it and tried to reinstall it. It is seen by the Bluetooth but it will not install. So I...
- turned off and turned on Bluetooth
- reset the Charge 5 (connected via charging cable)
- reset the Charge 4 (also connected via charging cable)
- rebooted phone..multiple times
- uninstalled and reinstall the Fitbit app
And still neither device is being seen by the app and will not install.
Any additional steps would be GREATLY appreciated.
Best Answer01-19-2023 14:39
01-19-2023 14:39
You can only have one of these devices connected to your account/app at a time. I would start there, and ensure the unused device is not within bluetooth range.
CharlesKn | Mid-Atlantic, USA
60+, strength and cardio
Charge 5, Android, Windows
Best Answer01-20-2023 01:59
01-20-2023 01:59
I have the same issue with my Charge 5 syncing….. and it’s the only Fitbit I have. It is always near my iPhone by 5ft.
Best Answer01-20-2023 13:25
01-20-2023 13:25
@ddgaslin I would also make sure you have the latest Android app v3.73, which is supposed to specifically address issues with Android 13 and the "Fold" devices.
@Tellygal The general steps for syncing issues:
Some variations include:
Best Answer01-20-2023 13:38
01-20-2023 13:38
Thank you for your responses. Ihave tried eaxh of these synching steps- with version 3.73- and i still cannot get my chrge 5 to install. This is getting frustrating....
Best Answer01-20-2023 13:56
01-20-2023 13:56
@ddgaslin By "install" I assume this means the app does not recognize or connect to your Charge 5. Is that correct? If so, I would contact Fitbit support.
Best Answer01-23-2023 07:35
01-23-2023 07:35
The app sees the Charge 5 (and the Charge 4 when I attempted to install it), then refuses to install it. It just keeps telling me to try again.
