10-11-2024
15:38
10:58
10-11-2024
15:38
10:58
Hi, I have a charge 5, my friend has a charge 6. We did a 5 hour strenuous hike, both of us using hiking poles. I set my charge 5 to measure a run (meant a hike, but oh well). She just let the charge 6 record her steps. My charge 5 on the ‘run’ measured a duration of 4h 56m, 15.21km, 20,349 steps. Hers measured approx 10,000 steps and 10.2 km. Why would there be this much difference? Aud
Best Answer10-12-2024 11:01
10-12-2024 11:01
Hi there, @AudMcF. Welcome to the Fitbit Community Forums.Thanks for bringing this to my attention and for all the details provided. I understand your concern, I will do my best to help you with this!
As a first approach, I would like to clarify that it's normal that you see a difference when you are comparing your data with another person, this is because Fitbit devices record your data based on your personal information (age, gender, weight and height).
If you feel that your step count and distance are inaccurate, confirm the following are correct in the Fitbit app:
On a side note, please bear in mind that Fitbit devices use the formula below to calculate distance. Your stride length is determined by your height and sex. Steps x Stride Length = Distance Traveled
Please note when you track an activity with GPS, your device calculates your distance using GPS data rather than steps. If you begin moving before you get a GPS signal, your device calculates distance using your steps until GPS connects.
To update your stride length, track a run with GPS or measure your stride length manually. For more information, see Can I change my stride length in my Fitbit account?
For more information about GPS, see How do I use GPS on my Fitbit device?
Best Answer10-12-2024 15:13
10-12-2024 15:13
