Charge 5 battery and screen issues
Hello,
I bought my Charge 5 in October 2022, this Tuesday the screen turned into black and the battery drained so fast. I have tried all the steps what I have found here, without any results.
2 REPLIES 2
Welcome to the Fitbit community, @SunsetRunner!
Sad to hear that your Charge 5 isn't working as expected.
Thanks for having tried to fix issues yourself. First I'd suggest fully charging your device. Please have a closer look here to make sure your device is able to get charged properly:
How do I charge my Fitbit device?
Why isn't my Fitbit device's battery charging?
Also I'd like to point out that restarting Charge 5 sometimes may take several attempts to be successful. So I'd recommend trying to restart it again closely following these instructions as timing is crucial for this procedure:
1.) Connect your Charge 5 to the charging cable which has to be connected to a reliable power source.
2.) Press the button located on the flat end of the charging cable 3 times within 8 seconds(!), holding each press for about 1 second(!).
3.) Wait around 10 seconds until the Fitbit logo appears on your device's display.
I'll keep my fingers crossed.
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Charge 6, Versa 4, Aria, Aria 2
Dear Talahthas,
Thank you for your answer, but as I wrote I tried all methods what I've read here. As it is within 1 year, I have sent back to a warranty repair this morning to the seller.
