10-08-2024
04:40
08:13
FatimaFitbit
10-08-2024
04:40
08:13
FatimaFitbit
Fit bit charge 5 battery is draining within few hours.Now the heart rate sensor ,ECG and EDA also stoped working.Probably after recent firmware update the issue started. Green lights of sensor are also not visible.Many people are facing same issue it seems.Fit bit please help to fix this asap.
Best Answer10-12-2024 11:20
10-12-2024 11:20
Hi @Satej. Welcome to the forums.
Thank you for sharing the inquiry regarding your Charge 5.
If you haven't done so yet, please try to restart the device as indicated here: How do I restart my Fitbit device?
Please, make sure to follow the steps listed in this help article: Why isn't my Fitbit device's battery charging?
Best Answer10-12-2024 12:31
10-12-2024 12:31
I have the exact same problem, restarting the devise did not work.
Best Answer10-13-2024 06:26
10-13-2024 06:26
I tried to restart multiple times but still it isn't working.Please help.The problem startes post latest firmware update.
Best Answer10-13-2024 07:05
10-13-2024 07:05
My battery is draining quickly in the last 2 days I've done the reset and that didn't help, now what? Thank you!!
Best Answer10-15-2024 23:47
10-15-2024 23:47
Hi ,
Tried restarting but it isn't working for me as well for many other people who are facing the same issue.Can you please fix it.It seems clearly to be a firmware update issue as the problem started after updates and is faced by everyone who has updated in a similar fashion.
