03-18-2024
07:00
07:11
03-18-2024
07:00
07:11
I have had my charge 5 for 3 months, battery drains within 2 days, the app doesn’t work properly when clicking on exercise doesn’t always sync either, I have had it three months and it been like this ever since the start
Hi there, @DeborahRad. Welcome to the Fitbit Community Forums. I'm sorry to hear that the battery of your Charge 5 is draining quickly and it also seems to experience syncing difficulties. I will do my best to help you with this!
Regarding the battery short life, in general, it is recommended to follow the recommendations listed in this article to improve or extend battery life. There are a few features that would make the battery drain faster than usual, even in one day. Some of these features are:
If this doesn't apply to you, another step that has been helpful for other users having battery draining problems is the three pulse restart procedure using the charging cable. Nevertheless, since you mentioned you already tried that, please confirm that you performed the restart as described below:
As for the syncing issue, I suggest following the troubleshooting steps provided in this help article Why won't my Fitbit device sync?
Best AnswerHello @DeborahRad
Since you've tried the recommended troubleshooting steps without success and you've had your device for less than a year, you should contact Fitbit support (<-- click link) to find out what are your options under warranty.
