09-26-2021
21:25
10:29
DavideFitbit
09-26-2021
21:25
10:29
DavideFitbit
I have had the new Charge 5 for 2 days. The battery discharges within a day. GPS is off, the phone is not set to always on. In looking over the troubleshooting instructions from Fitbit, it seems that you essentially have to disable all of the features that were selling points of this device in order to get decent battery life. Even my ancient Charge 3 got 6 days on one charge! Has anyone with this battery problem found a solution other than disabling everything?
05-18-2022 19:25
05-18-2022 19:25
05-19-2022
06:08
13:34
EdsonFitbit
05-19-2022
06:08
13:34
EdsonFitbit
After wiping the data from my Charge 5 and just leaving it unpaired the battery only drained 1% in over two hours.
Like GDShulz said - there seems to be plenty of evidence that it is not really a "battery" issue and more likely a battery drain issue.
Watching the Bluetooth connection "waffle" back and forth lead me to believe there is a compatibility issue - whether it's Fitbit firmware / software or iPhone software or a combination of both. I've really tried to be patient with Fitbit because I understand the issues they face with different platforms / hardware / OS / etc.
One other thought I had - in a previous thread a Fitbit tech support blamed the battery drain on communication between the Charge5 and the phone.
I wonder if the user account / associated data has any affect?
I've had the same Fitbit account for many years, going through a variety of different devices. I'm also a heavy phone user - with hundreds / thousands of emails per day, dozens (even hundred during conversations) of MMS messages...calls, voice mail notifications...
In the past few weeks I haven't used my Fitbit as a fitness tracker at all - obviously it can barely handle a few hours away from a charger - so it's definitely not GPS or massive fitness tracking / walk / run / bike tracking!
I can just imagine if the device had an issue syncing data and was constantly trying to send an entire "bucket" of data back and forth it might have a drastically different battery life.
Moderator edit: format
05-19-2022 10:15
05-19-2022 10:15
And here in lies one of the problems. I'd love to follow your suggestion. But they won't allow it. I've been using fitbits since according to my dash board 2016. I've purchased at least 8-10 devices from them. For myself and as gifts. I really liked my charge 5 until this issue happen. I purchased mine in November of 2021. This battery issue is new for me. It started about 3 weeks ago. I've done everything that has been suggested. After charging it 100% and restarting it does seem to give me a longer battery life. Like everyone else has said and I've said multiple times, this is an issue for their tech team to fix. Someone in Customer Service or a moderator should know about this discussion and they should be addressing it and reassuring us they will fix it. Not by having us turn every function off. Not by having to restart every time we charge it. Admit there is an issue and address these comments in this forum.
05-19-2022 20:24
05-19-2022 20:24
05-20-2022 02:40
05-20-2022 02:40
I was having this issue with my new charge 5. If I manually restart from the charge 5 display every night I get the advertised battery life. While not 100% ideal it works very well and overall happy with the device
05-20-2022 03:03
05-20-2022 03:03
I’ve had mine since December 2021 and have always had an issue. It seems to be worse when I have to use the “dynamic” gps since I cannot get my phone to connect for gps exercises. 100% charged Wednesday night and down to 40% this morning after 2 walks with dynamic gps. Anyone have any good tips to have the phone gps connect without having to try 20 times and 5 minutes of trying?
05-21-2022 05:49 - edited 05-21-2022 06:42
For some reason I've never been able to get the 100% + Reboot to affect my FitBit.
I did get it to last for almost 3 days when I removed the device from my account and "forgot" it from my phone's Bluetooth list.
However, as you said it really doesn't seem to be a "physical" battery problem, there is something else going on!
05-21-2022 15:16
05-21-2022 15:16
One more issue. I've had the C5 2 or 3 months now. I was very happy the 1st month or two. Battery was lasting 10-14 days. A while ago I decided to take a walk and use the GPS feature. I only used it once for a walk, but ever since battery loses 35-50% per day. I've restarted and doesn't help.
05-22-2022 09:13
05-22-2022 09:13
Just got mine 2 days ago and did the same thing. I let it deplete to 0% then recharged it and rebooted it. With all the stuff on now, it's dropped 3% in half a day. Sounds like it's software related. Something in the background was depleting it.
05-22-2022 09:48
05-22-2022 09:48
6% per day seems very good, that's more than 14 days.
05-22-2022 18:54
05-22-2022 18:54
05-22-2022 19:11
05-22-2022 19:11
It might work for you, I hope it does but its likely to happen again. I tried pretty much everything that newcomers to the now 40-page thread are suggesting. Unless Fitbit releases an official fix, it's either going to happen again or not work for everyone. Even if you do get a steady and reasonable battery drain after the full charge and reset, you might get a sudden and unexpected drain. Best to monitor the results for a few full battery cycles to be sure and even then, it might still randomly happen.
05-22-2022 19:27
05-22-2022 19:27
05-23-2022 06:37
05-23-2022 06:37
Same problem here. First it stopped tracking. I was able to reset it and the tracking works but the battery dies after several hours. GPS set to phone and screen is manual. I’ve only had this watch for six months. Very frustrating.
05-23-2022 13:29
05-23-2022 13:29
Looks like get to join the cool kid battery drain club...this is ridiculous.
05-23-2022 14:43
05-23-2022 14:43
Hello Again Fitbit Moderators,
Any news on the 'fix', without a proper solution soon my intention is not to renew my premium membership and move to a competitor's product.
05-23-2022 16:57
05-23-2022 16:57
I am having the same battery issue as others here including @Jopaggio. Can someone from Fitbit provide an update on progress towards the proposed firmware fix?
05-24-2022 17:46
05-24-2022 17:46
So… is this a code bug that will be fixed with a patch (I have seen this mentioned but but by anyone “officially from FitBit) Or is the only something to try to turn everything off and restart? Because I’ve tried all that and I’m still losing 100% battery in a 24 hour time span. Plus, I want to actually use the features. I’d just like some realistic direction in if a patch is coming or if I should exchange this device.
05-24-2022 23:22
05-24-2022 23:22
All these complaints within the Fitbit community, it's not going to be as effective as we, the Charge 5 user, hoping for. If only all these can be view by the public, as in by those who hasn't bought this faulty product. Fitbit might put a bit more urgency into solving this issue. Right now, it's only among the community who already bought the product.
05-25-2022 02:12 - edited 05-25-2022 03:00
The community here is great and Fitbit should be grateful to those who show an amazing amount of patience and perseverance as the promised firmware patch is created.
I would like to suggest that all those who have reported an issue with their Charge 5 be given at minimum a full year of premium at no charge.
WHAT DO YOU SAY FITBIT?
Oh, BTW how about letting us know the expected timeline on the FIX.
