09-26-2021
21:25
10:29
DavideFitbit
09-26-2021
21:25
10:29
DavideFitbit
I have had the new Charge 5 for 2 days. The battery discharges within a day. GPS is off, the phone is not set to always on. In looking over the troubleshooting instructions from Fitbit, it seems that you essentially have to disable all of the features that were selling points of this device in order to get decent battery life. Even my ancient Charge 3 got 6 days on one charge! Has anyone with this battery problem found a solution other than disabling everything?
06-21-2022 12:08
06-21-2022 12:08
It sucks bro. I had a streak of about 100 days of hitting my step goal and i lost it because my battery died and I didn’t realize and was short by 70 steps. Which I did in reality but now my streak is gone I’m so mad this needs to be fixed like a long **ahem** time ago already
06-21-2022 16:17
06-21-2022 16:17
Would anyone from Fitbit be able to clarify if this reported issue is related or a different issue? and if that firmware patch will also include this fix?
https://www.engadget.com/fitbit-charge-5-disconnection-fix-210142988.html
https://9to5google.com/2022/06/20/fitbit-charge-5-disconnecting/
I see from the articles there is still no ETA, so any additional information would be helpful and appreciated
06-21-2022 18:44
06-21-2022 18:44
I have the same issue, in fact, I've created a post that describes the same matter
I do believe that the latest firmware update screwed things up. I don't know how much time are they going to invest to fix this matter. Either rollback to a previous version or deploy a hotfix....you are Google now Fitbit...
06-21-2022 20:48
06-21-2022 20:48
Same here I only get 1 hour of usage on a full charge
06-21-2022 21:24
06-21-2022 21:24
I'm having the same issue. I could previously go almost 5 days without needing to charge my Fitbit. Then a couple of weeks ago it went dead and didn't seem to charge. I tried the help chat to resolve and they asked me to reset it and then asked me to email a video of me restarting the Fitbit, saying they would follow up via email. They didn't respond until today and asked me to resend the video in a different format, very frustrating! However, I did discover that my Fitbit was charging but then the battery was draining within an hour or so. The green light sensor on the back of the Fitbit is staying on constantly rather than flashing as it did previously. I think that is what is causing the problem and shared that with Fitbit. Hopefully they'll respond back with helpful advice!
06-22-2022 09:22
06-22-2022 09:22
Any updates from @Fitbit support???????????
06-22-2022 19:52
06-22-2022 19:52
Interesting. My fitbit today drained within an hour while I was exercising, but after a recharge is back to normal. I actually checked the green light and is flashing or off altogether right now! Will keep an eye out.
06-23-2022 02:18
06-23-2022 02:18
Mine is draining almost immediately, in less than an hour. Bought mine in November 2021 and would like answer to issue sooner rather than later. Have done all the suggested fixes and restarts to no avail.
06-23-2022 04:24
06-23-2022 04:24
Have had my Fitbit Charge 5 for about a week. Very disappointed. A full charge is only lasting 2 days maximum. My other Fitbits have lasted well over a week😥😥😥
06-23-2022 05:30
06-23-2022 05:30
same here, after two hours the battery is empty
06-23-2022 07:26
06-23-2022 07:26
Mine too! And wait for it:
I've spoken to their help team three times now and their response is to reboot it and not use the GPS. A feature I'VE NEVER USED. The best part! According to Fitbit, it's a "known issue and they're working on it" IE we know we sold you something defective and now you're stuck with it. Even with their replacement plan, they won't replace it because they know the replacement will do the exact same thing. Plus, they're still selling them! Knowing they stop working! Knowing they'll do nothing about it! So you aren't alone and there is ZERO that they will do.for any of us.
06-23-2022 09:55
06-23-2022 09:55
I've been having the same battery drain issue. I turned off Location access on my phone (it says location access is required to sync, but it still syncs just fine), then rebooted the Fitbit and fully charged it. 15 hours later, I am still at 96%. Fingers crossed something was fixed!
06-23-2022 15:41
06-23-2022 15:41
Mine is exactly the same, it’s shockingly bad!
06-23-2022 15:45
06-23-2022 15:45
Mine is exactly the same. It was holding battery for 4/5 days and now I’m lucky if I get an hour before it goes to ‘critical’ making it utterly useless even just as a watch! I’m shocked at how Fitbit are allowing this to continue and I’m sick of contacting the live chat to get the same generic replies.
06-23-2022 16:19
06-23-2022 16:19
I’m just going to keep tagging @Fitbit until they have enough respect for their customers to offer some sort of reply.
06-23-2022 16:23
06-23-2022 16:23
My Charge 5 battery dies the moment I take it off the charger. It has not worked since Memorial Day 2022! I’m sick of this issue. I contacted customer service and got the generic replies. I have tried everything and it is still an issue and I have been waiting for the firmware update they’ve been working on. I’m tempted to return the Charge 5 back to where I purchased it and buying a different brand!
06-23-2022 16:31
06-23-2022 16:31
I have been having same issue since Memorial Day 2022!
06-23-2022 17:07
06-23-2022 17:07
I think they must have down a new update as suddenly my Charge 5 is holding it's charge again. I was about to see if I could rollback the previous update when it suddenly came right.
06-23-2022 20:49
06-23-2022 20:49
06-24-2022 00:06
06-24-2022 00:06
here not - same issue
